Grid Jig "Koi"
i’m interested in this jig, described by Phil Jergenson (the inventor of Grid Beam) who was very excited about the design:
i don’t fully understand how it works, but i’d like to understand.
so i made a rough sketch for how i think this jig is supposed to work:
A sketch of a grid beam jig: the “positioner” is a flat bar with point-y etches in the side, laying on a table with a proto grid beam about to be drilled. A point-y bolt is in an initial pre-drilled hole on the proto grid beam, in the first etch on the positioner. A drill press is about to drill in the next hole.
After the hole is drilled, the point-y bolt will be pulled out of the etch, the beam slid forward until the point-y bolt is pushed into the next etch, then the next hole will be drilled. The process repeats until all etches are used to drill holes in the corresponding positions.
i started a GitHub repo: GitHub - villagekit/gridjig-koi: A simple jig to bring grid beam production to everyone. · GitHub
but i’m not sure how best to create the etches in the positioner, how best to create a point-y bolt, or how best to mount this to a drill press.
The proper way to make a pointy bolt is to use a metal lathe.
But you probably don’t have a lathe. But you have a drill press,
which is just like a metal lathe but with less steps.
A lathe spins the work and you move a tool into it.
A drill press spins a tool and you move it into the work.
But you can reverse this, put the bolt into the chuck, like it’s a drill, turn it on,
then carefully hold a file up to it until you’ve milled it down.
Or for extra noise and sparks you might use an angle grinder.
Because the bolt is spinning, if it’s aligned perfectly in the drill (check for wobble) then the point will be in the center of the bolt!
To make the jig, I think you just need to mark it very very carefully.
especially the first and last holes. Hmm probably the easiest accurate way to make notches like that would be to use a router with a V groove bit, like this V Groove Bits
I think the point of this design is that the pointy bolt goes into the point of the V, which is exactly where the hole should be. the notches just make it easier to move.
Alternatively, you could just use the drill press to make holes instead of notches. If the holes were narrower than the bolt point, it would rest on the edges of the hole on the 45 and be more positively aligned I think than just using the hole. You could also put the holes into a metal plate so that the holes dont get worn out.
The longer the jig the better. There will be some error between the first and last hole/notch, and if you have to reposition it 5 times, the total error between the first and last hole will be 5 times that. just making pencil marks and drilling them wouldn’t be good enough, because the drill might wonder, so instead scribe the marks then punch them. I would use a tape measure and a sliding square to mark the jig face, then scribe a line (always on the same side of the square, using a craft knife) then use the square again to measure the height, and scribe them, then use a punch to make a tiny round V at the intersection of the scribe marks. The drill tip will rest in there and not wander.
I think probably just do the first and last hole, then check the error by drilling a beam, but only the end holes, and measure to check if the accumulated error is acceptable, and if not, discard and try again.
Had these made, hoping it will work for the jigg
How did that template work out for you? I think the distance from the end holes to the edge needs to be half the distance between holes, i.e. .75inches instead of 1.5 inches. But that means you can probably just trim a bit off the ends to get the sizing right. (I’ve been working on getting a decent jig up and running. Without a laser cutter, it’s hard to get the precision right.)
