I’ve been working on a way to generate grid beams so that I can more quickly and accurately come up with designs in Rhino. So I made a Grasshopper script to generate the beams.
Happy to share the grasshopper file so you can make your own. Not sure the best way to share it here, If anyone has advice I’m open to it.
Whoa this is super interesting. I’m amazed at all the good info people were sharing with you as you worked through that problem.
My only thought is that to make tri-joints I’d want the lines spaced by 40mm instead of intersecting, so I am wondering if that would be a bunch of faff. Or do you think that I could write that into the Grass Hopper script too?
